Purge solenoid valve location
FRANKIEBOYTWO
  • 2007 SUZUKI XL7
Six cylinder two wheel drive automatic 82,000 miles.
Where is the purge solenoid valve located?
Thursday, September 9th, 2010 AT 6:24 PM
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2007_suzki_canister_purge_solenoid_part2_1.jpg
First of all thank you so much for your donation. If your talking about the canister purge solenoid it is located on the back side of the engine call out number 1 in the diagram i posted.
Thursday, September 9th, 2010 AT 6:56 PM
FRANKIEBOYTWO
  • 6 POSTS
Thanks for your reply saturntech9. Yes, I am referring to the canister purge vale. We are talking about the 3.6L, right? And by rear of the engine you mean the transmission side? Well, I do not see it where indicated in the diagram. It would have to be under the intake manifold if it is there.
Should it be easily accessible? The diagram actually looks somewhat different than what I see on my vehicle. Is the diagram specific to my vehicle? I understand my vehicle is the same as a Chevrolet Equinox if that helps narrow it down any.
Any further help is appreciated.
Thanks.
Friday, September 10th, 2010 AT 7:46 AM
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2007_suzuki_fuel_injector_sight_shield_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2007_suzuki_canister_purge_diagram_1.jpg
Yes i have the correct information and it goes to your car. Remove the engine cover i posted a diagram for look at the posted diagram you will see your throttle body and a hose by it that hose lead's to your canister purge solenoid as you can see in the diagram. It is on the opposite side of where you fill your oil.
Friday, September 10th, 2010 AT 11:00 AM
FRANKIEBOYTWO
  • 6 POSTS
After my first reply, I finally got oriented and found it. Not the setup up or look I expected. I had what I thought was the replacement GM part which looked totally different. Any ideas on a replacement cheaper than the $150.00 the dealer wants?
Friday, September 10th, 2010 AT 11:10 AM
SATURNTECH9
  • 30,870 POSTS
Glad to hear you found it is there a part number on it? If so can you give me that number I am trying to find you that part.
Friday, September 10th, 2010 AT 11:26 AM
FRANKIEBOYTWO
  • 6 POSTS
How about Bosch 12591334.
Friday, September 10th, 2010 AT 11:45 AM
SATURNTECH9
  • 30,870 POSTS
I found it on www. Rockauto. Com it is an ACdelco one for $21.79 it is listed under vapor canister purge valve it list your part number as a replacement. Just go there and look up your car and under emission's you will find it click the vapor canister purge valve tab and you can match up your part number with the ACdelco one as a replacement. The ACdelco part number is 2141685 when you order your part if you type in the how did you hear about us box 39356593242193 you will save another five percent off that price the code is good until November seventh. I have purchased a lot of parts off them so they send me discount code's. I thought I would share the saving's with you.
Friday, September 10th, 2010 AT 12:17 PM
FRANKIEBOYTWO
  • 6 POSTS
Done. Thanks for the information, Louie. You have been a great help. Hopefully, this will be the right one. No picture so I will not know until I get it, but at least all the numbers match up. Positive feedback and another donation will be forthcoming.
Friday, September 10th, 2010 AT 12:53 PM
SATURNTECH9
  • 30,870 POSTS
Glad to hear it Rockauto has a thirty day return policy but seeing how they listed your part number I do not see where you could go wrong there. Keep me posted on how it goes.
Friday, September 10th, 2010 AT 1:47 PM
FRANKIEBOYTWO
  • 6 POSTS
I will keep you posted.
Friday, September 10th, 2010 AT 3:07 PM
OASISJB
I just saw this question. I too have a code reading something to do with high flow purge. I think the code was p0406. Something like that. I replaced my gas cap but that did not solve the problem. I am guessing it is something to do with a purge solenoid or whatever. I am looking for a diagram or instructions on how to replace it but have not come across anything. Hoping you can help.
Thursday, March 15th, 2012 AT 2:48 PM
