HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Suzuki
Vitara
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
Car Won't Crank Over
STEFYW23
MEMBER
2008 SUZUKI VITARA
Where is the starter located in not working?
Sunday, August 23rd, 2015 AT 12:04 PM
HMAC300
MECHANIC
The starter motor is located back of block right hand side. Here is a guided to walk you through the steps and diagrams below to show you on your car
Images (Click to make bigger)
SPONSORED LINKS
Monday, August 24th, 2015 AT 7:35 AM
GIGIB2009
MEMBER
1 POST
2003 SUZUKI VITARA
6 CYL
2WD
AUTOMATIC
80,000 MILES
Sometimes, not always, engine will have to be turned over 1-5 times before it starts.
Monday, February 11th, 2019 AT 5:58 PM (Merged)
DAVE H
MECHANIC
Start by having the vehicle tuned/serviced
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Today, The Car Would Not Start. The Battery Appears...
Today, The Car Would Not Start. The Battery Appears To Be Good And I Can Hear The Sound Of It Wanting To Turn Over, But Doesn't. What...
Asked by
Daisyhaywood
1 ANSWER
2008
SUZUKI VITARA
GUIDE
Not Cranking Over
When your engine is not cranking (turning) over it will be mainly due to three separate areas, first it could be the battery, cables or poor connection, next is the starter...
2008 Suzuki Vitara Sudden Loss Of Power
This Fault Started Several Weeks Ago, Accelerating Up A Hill The Car Dropped Into Limp Mode, The Diagnostic Light Came On. Restarting The...
Asked by
Raul_zebra
2008
SUZUKI VITARA
Will Not Start
I Put A Timing Chain In This Car, Someone Else Had Already Tried To Put The Chain On And Time It, It Did Not Work. So They Brought It To...
Asked by
Matt N Amanda Solarchick
8 IMAGES
2002
SUZUKI VITARA
Lack Of Power, Limp Mode, Solenoid Valve
I Have A Grand Vitara Rhz Hdi 2.0. Every Time I Go Over 100 Km/hour The Check Engine Comes Up, The Truck Looses Power. I Have To Stop Shut...
Asked by
suzuki07
4 IMAGES
2002
SUZUKI VITARA
2002 Suzuki Vitara Car Quite At Stop Sign Car Will...
I Was Driving Home From Work. I Made It Two House Away From My House And Came To A Stop Sign Where I Had To Stop. While Coming To A Full...
Asked by
mwind27
2002
SUZUKI VITARA
VIEW MORE
SPONSORED LINKS
Battery Replacement Guide
Battery Replacement Ford
Starter Motor Replacement
Online car repair manuals
