Vitara Turbo Diesel goes into limp mode
SAFARIMAN
  • SUZUKI
Just bought a Vitara TD with HDI engine on a 52 plate for my daughter to use but it problem is that the engine management light comes on and then the vehicle goes into limp mode if the vehicle is switch off then restarted its fine until the next time which there is no pattern and can be any when. We have ran a diagnostic check and the code reads 0230 primary fuel pump circuit malfunction, need to know if this is relay related or controlled any help or ideas much appreciated. Many thanks Mike
Do you
have the same problem?
Tuesday, August 7th, 2007 AT 10:04 AM
DAVE H
Check/replace fuel pressure regulator
Tuesday, June 22nd, 2010 AT 2:18 AM
Recommended Guides
