Suzuki Sidekick makes a loud rubbing noise in hard turns
D ROCK
  • SUZUKI
Suzuki Sidekick, 1993, 137k miles, 4 door, 2WD, 1.6L
I am not sure if I can figure this one out on my own. I have a 93 suzuki sidekick that for several years, when I turn the steering wheel several rotations to the left or right, it makes a noise like rubbing rubber seals or something. I know that is does not have anything to do with the tires since I have had them changed and it still persists. I am wondering if there is some hub or seal connection that is worn out? If so, how do I change it.I would rather not spend the money on the repair if I can do it since the repair will come to what the car is worth :) Thank you in advance. :Shock:
Do you
have the same problem?
Wednesday, July 11th, 2007 AT 9:50 AM
DAVE H
  • EXPERT
Check for tires rubbing on interior wheel arch
Sunday, April 25th, 2010 AT 2:30 AM
Recommended Guides
