1993 Subaru Legacy car is over heating
CBLAND32
  • 1993 SUBARU LEGACY
Engine Cooling problem
1993 Subaru Legacy 4 cyl All Wheel Drive Automatic
what test can I run to find out y my car overheats
Do you
have the same problem?
Wednesday, January 21st, 2009 AT 12:35 PM
M_H_RITZEL
  • EXPERT
If the temp guage goes up and you do not loose fluid then the first thing I think about is the thermastat. If you are looseing fluid then I would have the system pressure checked. A number of things can make it overheat, . Not enough coolant, 2, clogged system, 3, a bad themstat. With the thermastat is usually the problem that I would change first first
Tuesday, January 27th, 2009 AT 8:43 AM
Recommended Guides
