1999 Subaru Forester check engine light
JULIE_RAINBOW69
  • 1999 SUBARU FORESTER
1999 Subaru Forester 96800 miles
I am getting frustrated my check engine light keeps coming on Iv taken it back to the dealership for diagnostic check they say its nothing except this last time after taking it to DEQ and not passing they said I needed a new battery so thats what I did drove it around then got gas and sure enough its on again. Took it back they claim its probably the gas cap. Any suggestions I've not passed DEQ 2x's now. Arrrgggg
Do you
have the same problem?
Monday, March 30th, 2009 AT 7:59 PM
BMRFIXIT
  • EXPERT
If its the gas cap
when you fill with gas make sure is off and after done make sure its tight and on correct
as for you to pass sticker
you need to have the codes check and tested and removed
drive car around and go back for the retest before filling up
if you know what you have for code I can try and look it up
and check the proper way to diagnose that code
let me know and good luck
Monday, March 30th, 2009 AT 8:09 PM
Recommended Guides
