Fuel pressure regulator?
AXSUNLMTD
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 70,000 MILES
I have a 2005 dodge Ram 1500 Hemi 4x4. It has been stalling, hesitating, when I press the gas it starts slow and then jumps out like it's ready to race all the while my foot is 1/6 of the way down (barely pressing the pedal) and I never moved it. I was told it's the fuel pressure regulator so I bought a tester for $13 and the reading is jumping from 60-78psi like it has a shaking disorder. I was told it was suppose to be a steady 49.2 and if it's below 44.2 it's the pump and if it's over 54.2 psi it's the regulator. Is that correct?
Tuesday, April 21st, 2009 AT 5:23 PM
  • 108,179 POSTS
That sounds correct.
Here is a how to for checking fuel pump performance. Also, keep in mind, if the pressure drops when you hit the gas, it could also be a clogged fuel filter. Actually, the pressure should raise when you gun the throttle. If you disconnect the vacuum to the fuel pressure regulator, expect the pressure to raise 5 to 10 PSI.
Here is the video:
https://www.2carpros.com/dia/test_fuel_pressure.htm
The fuel pressure regulator is part of the fuel pump I have included instructions in the diagrams below to show you how to replace it. Check out the diagrams (Below). Please let us know what happens.
Tuesday, May 12th, 2009 AT 1:30 PM
CAZ2022
  • 2001 DODGE RAM
  • 4WD
Can I replace the leaking quick connector from my fuel regulator to my supply line with
Monday, October 19th, 2020 AT 1:38 PM (Merged)
  • 52,797 POSTS
Being as it is fuel, I recomend getting the factory line. Splicing into the line with adapters does not always hold and could cause a fire. The lines ar reasonable. You can check at a dealers parts department for the part.
Monday, October 19th, 2020 AT 1:39 PM (Merged)
YUKONHEO
  • 1999 DODGE RAM
  • 5.2L
  • V8
  • 4WD
  • MANUAL
  • 153,000 MILES
I bought this truck last october, so im not to sure on its maintenance history. Since I got it ive replaced the Rad due to sever leak that was probably patched with an additive before the truck was sold since the leak started appearing about a week after I got it, and due to stains that were on the shroud im the same spot that was getting wet when the leak appeared. Other than the Rad change the only other things I did was change the air filter and and a small set of LED driving lights. Since that work was done its been running nicely. The only thing I did notice was that when I come to a stop after driving at almost any speed the RPM's would drop down to near 400 or less then go back to idle then drop once again about half as far then idle fine. It has stalled twice under the same conditions of coming to a stop. Recently though the truck decided to just quit running while I was driving in town. It had been running for at least an hour and a half that day and I had filled the gass tank the day before on my way home. Couldnt get the truck running so I had to leave it in the parking lot I had managed to coast into when the truck died.( Was short on time since I had to work a split shift that night and be back at work in half an hour after the truck died) So the next day I haul the truck to a shop I work at and at a later time me and a mechanic take a look at it. We started off with trying to crank it over a few times no luck other than the odd rough sputter every now and again. We pull the first two spark plugs on each side one at a time as we check for spark, Looks fine. Then we open up the distributor cap and check for corrosion also looks fine but we still gave it a couple scrubs with some fine grit and throw it back together. Crank it over same result. Hooked up the OBD and no codes came up. We at one point hooked a fuel pressure gauge to the rail and turned on the key we got 42psi and when we cranked it the gauge would wave between 35-50psi. So I bought a new fuel pressure regulator drained the tank dropped it put the new regulator into the pump hooking everything up the same as it was and tried to start it again, still no luck. Hooked the gauge back to the rail and turned the key on, jumps to 42psi. Turn the starter and psi stays pretty much the same. The mechanic suggested that my pumps not putting out enough and that I should have just got a new pump assembly anyways. So I did, just installed that today and tried again still the same results, mechanic hooks the gauge to the rail again and were getting 50 psi but once the pump kicks outthe psi steadily drops till I either turn it over or reset the key and turn it on again. At the moment I dont know hat else to do. I called the local dealership and they said check injector pulse(which I dont know how to do and the mechanic thinks it cant be an issue there( for some reason he thinks whenever I mention injectors im saying that they all failed at once and and thats not possible) the only other thing the dealership said it could be wass dirty spark plugs. Im going to buy a new set of spark plugs, and put the new regulator off the old pump onto the new pump also im thinking I might as well do an oil change while its in the shop as well. Couldnt hurt. But at this moment im stumped and starting to have doubts about our mechanic and starting to wonder if anyone else has some opinions or ideas on what my issue is?
HMAC300
  • 48,601 POSTS
See pics for testing your fuel pump if you have the old regulator still you may need that as it can be a check valve inside bad. Should not drop below 30 psi for 5 minutes. Follow these instructions and you should be able to find the problem.
YUKONHEO
Ya it looses almost all pressure in about 6 minutes, no leaks in fuel line or connections. Decided to leave the regulator alone on the pump and got another ordered to replace the current "new pump" since the regulator on it is faulty
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Okay please let us know what happens
TONETONE
  • 1997 DODGE RAM
V8 four wheel drive automatic 150,000 miles.
Where is the fuel pressure regulator located on my truck listed above it a 1500 with a 5.9 liter 360 engine?
BLUELIGHTNIN6
  • 16,542 POSTS
A combination filter and pressure regulator is used on your vehicle. The regulator is a mechanical device not controlled by the PCM or engine vacuum.
It is calibrated to maintain a pressure a pressure of about 49 psi (339 kPa) at the fuel injectors. The unit contains a diaphragm, calibrated springs and a return valve.
The regulator's pressure maintenance feature permits easier starting. If pressure exceeds the specified amount, the unit routs the excess fuel back to the tank.
Removal and installation:
Disconnect the negative battery cable.
Remove the fuel tank filler cap.
Properly relieve the fuel system pressure.
Raise and safely support the vehicle.
Remove the fuel tank assembly.
The fuel pressure filter/regulator assembly is located on the top of the fuel pump assembly. It is not necessary to remove the fuel pump to remove the pressure filter/regulator assembly. Match mark the direction the hose fitting points. Unit must be reinstalled pointing in the same direction.
Twist the filter/regulator assembly out of its grommet on the fuel pump.
Remove the snap ring that retains the convoluted tube to the filter/regulator. Slide the tube down the plastic fuel tube to access the fuel tube clamp.
Gently cut the old fuel tube clamp off, taking care not to damage the fuel tube or drop the clamp inside the tank.
Remove the fuel tube from the filter/regulator assembly by gently pulling downward.
Remove the filter/regulator assembly from the fuel pump module.
https://www.2carpros.com/forum/automotive_pictures/261618_0900c152800c0917_1.jpg
Install a new clamp over the plastic fuel tube.
Install the filter/regulator assembly to the fuel tube. Rotate the filter/regulator until it is pointed to line up with the matchmark previously made.
Tighten the clamp to fuel line using hose clamp pliers C-4124 or equivalent.
Slide the convoluted plastic tube up to the bottom of the filter/regulator and install the snap ring.
Press the filter/regulator assembly into the rubber grommet making sure it is pointed in the 10 o'clock position.
Install the fuel tank.
Lower the vehicle.
Connect the negative battery cable.
Install the fuel filler cap.
