Starting problems
SHELLY LAMONS
  • 1995 NISSAN ALTIMA
  • 300,000 MILES
I have a 1995 Nissan Altima it would die on me when I would be driving down the road I'd wait 5 or 10 mins and it would start back up well when I went to start it one morning it wouldn't start and has only started twice since then and would die after a few mins so my husband who is out of town working told me to check the spark plugs while when I did 2 of them was full of oil would this have anything to do with it not starting I've been told that it's vapor locked and also told my oil rings need to be replace or put a new motor in it plz help me thank you
Do you
have the same problem?
Friday, February 19th, 2016 AT 2:25 PM
WRENCHTECH
  • EXPERT
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Friday, February 19th, 2016 AT 3:04 PM
Recommended Guides
