Starting problem
RONALDHEADRICK
I am sorry here they are:
Thursday, September 19th, 2019 AT 10:01 PM
  • EXPERT
Okay, do you have a scan tool that can read live data?
Friday, September 20th, 2019 AT 4:52 AM
RONALDHEADRICK
I think I have them right now. I have been having internet problems.
Friday, September 20th, 2019 AT 1:50 PM
RONALDHEADRICK
No, I don't have a scan tool. Can I rent one from O'Reilly's?
Friday, September 20th, 2019 AT 1:55 PM
RONALDHEADRICK
The only scan tool I have is what I could possibly rent. Do you have any recommendations maybe there is some place I can get the scan done?
Friday, September 20th, 2019 AT 2:03 PM
RONALDHEADRICK
What would a scanner that can read live data cost me to buy if possible?
Friday, September 20th, 2019 AT 2:05 PM
  • EXPERT
A good scan tool will cost about $2,000.00 to $3,000.00.
You could have a mobile mechanic come to you and check it for you as well. That would be cheaper by a ton.
Friday, September 20th, 2019 AT 2:42 PM
RONALDHEADRICK
What just search for a mechanic that can run a scan with live data.
Friday, September 20th, 2019 AT 6:10 PM
  • EXPERT
And help you diagnose the failure, yes. Otherwise, you need to get it to a shop and have the testing done.
Friday, September 20th, 2019 AT 6:18 PM
RONALDHEADRICK
I can rent anyone of these scanners and they say graphing live data, searching live data, and then they have live data and freeze frame data. Can I get lucky enough and one of these will work for what you are talking about?
Saturday, September 21st, 2019 AT 4:48 PM
  • EXPERT
The graphing of live data is what you are looking for to see spark and injector on times.
Saturday, September 21st, 2019 AT 5:09 PM
RONALDHEADRICK
That is awesome. I will get the scanner as soon as O'Reillys opens.
Saturday, September 21st, 2019 AT 5:44 PM
  • EXPERT
Sounds good.
Saturday, September 21st, 2019 AT 5:51 PM
RONALDHEADRICK
Ok Roy I just wanted to let you know were I was I bought a bosch OBD 1200 scanner but know I almost have to go back to school to program the scanner and teach me how to use the scanner I should be ready tomorow
Monday, September 23rd, 2019 AT 2:27 PM
  • EXPERT
Sounds good.
Monday, September 23rd, 2019 AT 2:38 PM
RONALDHEADRICK
Hello Roy, sorry it took so long. But I have some information and 2 pictures with I hope my answer. I have replaced the coil and the ignition control module right next to the coil. I have not replaced the throttle positioning sensor or that plug that is in the distributor.
Saturday, September 28th, 2019 AT 3:36 PM
  • EXPERT
The most common problem is the coil itself. I would start there.
Saturday, September 28th, 2019 AT 3:40 PM
RONALDHEADRICK
I have replaced the coil the ignition control module distributor cap and bug, plugs and wires. The only thing I have not replaced is that module that is under the rotor bug and has a plug that plugs into it. Can the throttle positioning sensor cause the problem I am having? I saw the scanner said something about the throttle positioning sensor. Could that be my problem?
Sunday, September 29th, 2019 AT 1:05 AM
  • EXPERT
351 is not a code for your vehicle. Are you sure we are talking about the Astro?
I see the 351 is one of 8. What are the other 7?
Sunday, September 29th, 2019 AT 4:18 AM
RONALDHEADRICK
Here is some more info from the scanner:
Sunday, September 29th, 2019 AT 6:33 PM
