Starting problem
RONALDHEADRICK
Well Roy, I have installed the ignition switch and there is no difference. I am going crazy. What do I need to do now?
Monday, September 9th, 2019 AT 11:50 AM
RONALDHEADRICK
I hope you got my message that the ignition switch did not fix the problem that next.
Monday, September 9th, 2019 AT 11:52 AM
  • EXPERT
I attached a wiring diagram of the ignition switch. Verify power to both sides of the switch from the fuse block. Make sure there is power there with the key on.
If that is good, then test for output power at the bottom on the highlighted wires with the key on.
Monday, September 9th, 2019 AT 3:25 PM
RONALDHEADRICK
Okay Roy, I have some information and need some info you had me check 2 wires going in and then you have 5 brown, orange, yellow, white, and pink are those wires coming out of the back of the ignition plug that I replaced and the wires I need to check are the bigger ones correct. I'm sorry but I can't make heads or tails of that wiring diagram. I don't have much knowledge of wiring except what I have taught myself.
Wednesday, September 11th, 2019 AT 1:39 PM
  • EXPERT
Okay, the 2 wires at the top are inputs to the switch. Make sure there is a power to those wires. Use a test light or voltmeter. The colors are listed.
The ones on the bottom are outputs. Make sure those wires have voltage with the key in the on position.
Wednesday, September 11th, 2019 AT 1:53 PM
RONALDHEADRICK
Those 5 output wires are the big ones right?
Wednesday, September 11th, 2019 AT 3:33 PM
  • EXPERT
That is correct.
Wednesday, September 11th, 2019 AT 3:43 PM
RONALDHEADRICK
Thank you. I will get back with you tomorrow after I check those output wires thanks again.
Wednesday, September 11th, 2019 AT 3:45 PM
  • EXPERT
You are welcome.
Always glad to help.
Wednesday, September 11th, 2019 AT 3:47 PM
RONALDHEADRICK
Well I checked all of those wires and they all were right except the big yellow output it is only hot while the van is cranking when you let it go out of the cranking into the on it goes out.
Thursday, September 12th, 2019 AT 1:03 PM
  • EXPERT
Okay, good job.
Now, go to the fuse block under the hood. There should be a wire to it that is secured by a nut.
Check the voltage there with the key on.
Thursday, September 12th, 2019 AT 1:06 PM
RONALDHEADRICK
I am sorry for the time, but I don't have a voltage gauge. I will have one this Friday and will get back to you would it help for me to rent a code reader from the parts store can I use one without the can running.
Monday, September 16th, 2019 AT 10:07 AM
  • EXPERT
Okay, keep me updated.
Monday, September 16th, 2019 AT 10:16 AM
RONALDHEADRICK
Would it be worth my time to rent a code reader and see if it has any codes that could cause the problem I'm having?
Monday, September 16th, 2019 AT 10:37 PM
  • EXPERT
No, that will not tell you any readings at all.
You need to do manual testing.
Tuesday, September 17th, 2019 AT 3:45 AM
RONALDHEADRICK
Okay, I will have my multi-meter sometime this afternoon and will check the voltage and get back to you.
Tuesday, September 17th, 2019 AT 9:26 AM
RONALDHEADRICK
Okay, there are three wires secured by a nut.
Tuesday, September 17th, 2019 AT 9:36 AM
  • EXPERT
Make sure they all have power.
Tuesday, September 17th, 2019 AT 9:38 AM
RONALDHEADRICK
Okay, so those are the one your talking about and it's not under the fuse block.
Tuesday, September 17th, 2019 AT 9:41 AM
RONALDHEADRICK
It not under the fuse block.
Tuesday, September 17th, 2019 AT 9:42 AM
