Starting problem
RONALDHEADRICK
  • 2003 CHEVROLET ASTRO
  • 4.3L
  • V6
  • 187,000 MILES
When I try to start the van it will start for about 1 to 2 seconds then shuts off. It has all new distributor cap and bug plugs and wires, coil, and ignition control module and a new fuel pump but still shuts off immediately after starting.
Do you
have the same problem?
Wednesday, September 4th, 2019 AT 3:34 PM
ROY B
  • EXPERT
Good evening,
Is the theft or security light on? Sounds like it is in lock out.
I attached a guide to reset the security system. Try that and let me know if that was it.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Wednesday, September 4th, 2019 AT 4:22 PM
RONALDHEADRICK
Okay, you say the pass-lock okay. What started the problem is my ignition key would not turn so I had to drill it out and put a new key tumbler in it. Well then I finished and went to start the van it would only start for a second and shut off. This happen before and I replaced the distributor cap and bug plugs, the plugs and wires and it fired right up and then the key happen and here I am.
Thursday, September 5th, 2019 AT 12:24 AM
ROY B
  • EXPERT
Did you try the reset procedure?
Thursday, September 5th, 2019 AT 2:08 AM
RONALDHEADRICK
No, I am fixing to do that right now.
Thursday, September 5th, 2019 AT 5:13 AM
ROY B
  • EXPERT
Keep me updated.
Thursday, September 5th, 2019 AT 5:19 AM
RONALDHEADRICK
I did the reset and nothing. The security light is not on. I added a video clip it is more audio on what's going on.
Thursday, September 5th, 2019 AT 7:26 AM
ROY B
  • EXPERT
Good.
This sounds like it starts in the start position but turns off it the run position. This tells me the ignition switch may be the issue.
Ignition Switch Replacement- On Vehicle
Removal Procedure
Caution: Refer to SIR Caution in Service Precautions.
ImageOpen In New TabZoom/Print
1. Disable the SIR system.
2. Remove the steering column trim covers from the steering column.
3. Disconnect the steering column electrical connectors.
4. Remove the steering column wiring harness tie straps.
5. Remove the steering column wire harness (1) from the steering column and the wire harness strap (2).
6. Remove and dispose of the small wire harness straps from the wire harness assembly (1).
7. Disconnect the multifunction switch electrical connectors (2) from the bulkhead connector (1).
8. Remove the key alarm connector (1) from the lock module assembly (2) in the following way:
8.1. Rotate the key alarm connector (1) 90 .
8.2. Pull the key alarm connector (1) out of the lock module assembly (2).
8.3. Remove the passkey connector from the lock module assembly (2).
9. Slide the ignition and key alarm switch assembly (2) out of the lock module assembly (1).
Thursday, September 5th, 2019 AT 7:35 AM
RONALDHEADRICK
I don't understand the imageopen in new tabzoom/print. What does that mean?
Thursday, September 5th, 2019 AT 10:10 AM
ROY B
  • EXPERT
The images are attached below. We cannot put the images where they should be. They have to sent as a separate attachment.
Thursday, September 5th, 2019 AT 10:26 AM
RONALDHEADRICK
I have some more information for you. When I drilled out the key tumbler and replaced it I replaced it with a new tumbler from my 1996 Chevrolet Silverado pickup it slipped right in and mechanically worked like the old one. Is there something in the actual key tumbler for the van that this tumbler does not have? Because I noticed buying one it starts at $2,000.00 and goes up and the one I used is from a 1996 the key even looks different.
Thursday, September 5th, 2019 AT 10:32 AM
RONALDHEADRICK
Okay, thank you about the pictures.
Thursday, September 5th, 2019 AT 10:34 AM
ROY B
  • EXPERT
It has a transponder for security. You stated the theft or security light is not on?
Does it come on with the key and go out after about 10 seconds?
Thursday, September 5th, 2019 AT 10:39 AM
RONALDHEADRICK
Yes it does.
Thursday, September 5th, 2019 AT 10:45 AM
ROY B
  • EXPERT
Then it is not a security issue at all.
Thursday, September 5th, 2019 AT 11:18 AM
RONALDHEADRICK
Can it still be the ignition switch?
Thursday, September 5th, 2019 AT 11:42 AM
ROY B
  • EXPERT
Sure can. That is my suggestion.
Thursday, September 5th, 2019 AT 11:52 AM
RONALDHEADRICK
Okay, thank you. That is what I am going to do. I don't have the past for a couple of days but I will get back with you as soon as I get it finished. It will probably be somewhere around next Friday. But thank you for the information you have giving me so far I appreciate it a lot.
Thursday, September 5th, 2019 AT 12:36 PM
ROY B
  • EXPERT
You are welcome.
Always glad to help.
Keep us updated.
Friday, September 6th, 2019 AT 8:02 AM
RONALDHEADRICK
Hello Roy, my van has some kind of aftermarket something that is spliced into the ignition switch harness. Can I take it all out when I put the new switch in the van?
Friday, September 6th, 2019 AT 2:40 PM
ROY B
  • EXPERT
Sure, could be a remote starter or security.
Friday, September 6th, 2019 AT 3:17 PM
