Starting problem
CAJUNGUY65
  • 1998 FORD F-150
  • 5.4L
  • V8
  • 4WD
  • 205,000 MILES
I recently purchased this vehicle. The guy I bought it from told me he had fuel pump and fuel filter changed. Also plugs and wires. The gas tank was empty so I put ten gallons of fresh gas. When key switch is turned on I can hear fuel pump pumping. It will not even turn the engine with the key. I bypassed the key using the solenoid switch. It turns over and starts but runs for only a few seconds. What do you think can cause that? I scanned for codes. Nothing showed. No codes at all. Thank you for your time.
Do you
have the same problem?
Monday, April 10th, 2017 AT 4:37 PM
CATAFINA
Try the inertia switch
Tuesday, April 11th, 2017 AT 1:16 AM
HMAC300
  • EXPERT
Previously answered
Tuesday, April 11th, 2017 AT 6:04 AM
Recommended Guides
