Starting problem
MCGD
  • 2006 KIA RIO
  • 85,000 MILES
Car starts fine when engine is cold (ex: morning) but not when it's warm/hot after some driving. It restarts after about 30 minutes or so. I've read this could be a sensor problem? I asked this before but just got an article about the different possibilities if a car doesn't start, without considering the specifics of my case (cold vs. Hot engine). I've already tested the battery which is fine. Do you agree that it could be a sensor problem (air temperature sensor or something else)? Thank you.
PS I'm going to choose electrical as the repair topic but i'm not sure that's what it is.
Do you
have the same problem?
Tuesday, April 30th, 2013 AT 9:41 PM
  • EXPERT
I would start with a fuel pressure test
Wednesday, May 1st, 2013 AT 2:24 AM
Recommended Guides
