Starting issues
SID1398
  • 2003 TOYOTA SEQUOIA
  • 180,000 MILES
The truck will start and then stop a few seconds later. Then it will start fine on the second try. It also starts bucking if I give it a lot of gas. There are no vacuum leaks. I've changed the fuel filter and mass air flow sensor. I also cleanes the throttle body. There are no codes. Any ideas? Thanks
Do you
have the same problem?
Wednesday, April 17th, 2013 AT 1:47 PM
DOCFIXIT
  • EXPERT
Check fuel pressure
Wednesday, April 17th, 2013 AT 1:58 PM
Recommended Guides
