Starter location
ANONYMOUS
  • 2005 KIA SORENTO
  • 125 MILES
Where is the starter located on this Sorento?
Saturday, November 3rd, 2012 AT 10:57 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,840 POSTS
It is under the car in a bad spot sandwiched between the engine block and the catalytic converter. Here are tow guides that will help you get he job done and a picture from the internet. Take some time and you can get it done.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
and
Here is the starter from Amazon made by Kia which when you are replacing it I would go for becasue there is nothing worse than putting it back together and have a rebuilt unit poop out and you will need to do the job all over again.
https://www.amazon.com/gp/product/B00L2PGXYE/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B00L2PGXYE&linkId=9c87e022f02ec8ce452c082b336aac19
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
Friday, September 15th, 2017 AT 5:46 PM
DEREK ADAM PITCOCK
  • 2004 KIA SORENTO
  • 3.5L
  • 6 CYL
  • 4WD
  • 150,000 MILES
Do I need to remove anything to take starter off to replace it?
Friday, September 15th, 2017 AT 5:51 PM (Merged)
KEN L
  • 42,840 POSTS
You will need to raise the car and disconnect the battery cable before you begin. Here is a guide that will show you what you are in for when changing the starter motor.
Cheers, Ken
BMADISON14
  • 2003 KIA SORENTO
  • 175,000 MILES
What has to be removed in order to get to the starter? Do the engine have to come out?
Sunday, December 30th, 2018 AT 11:40 AM (Merged)
  • 108,133 POSTS
The engine doesn't need to be removed, but Kia was nice enough to make it a nightmare.
First, make sure you disconnect the battery before doing any work. Next, safely lift the vehicle and remove the skid plate (if your vehicle has one). After that, you need to lower the exhaust from the exhaust manifolds. Once that is done, remove the heat shield from the starter (I believe there are three bolts). Once it is off, you can then access the wiring and the mounting bolts.
I wish I had pictures and specific directions for the procedure, but they are not available from the manufacturer.
Here is a link to this same question:
https://www.2carpros.com/questions/2005-kia-sorento-starter-located-on-this-sorento
BMADISON14
Thank you so much! You are absolutely amazing! Wishing happy holidays
