Starter
LISA97266BROWN
  • 1994 MITSUBISHI GALANT
  • 200,000 MILES
Took starter off cleaned it put it back on was fine for 12 hours and now the starter stays running when I started it I had to disconnect the battery cable and if I try to connect it back up it still runs
Do you
have the same problem?
Thursday, May 30th, 2013 AT 6:26 AM
WRENCHTECH
  • EXPERT
What exactly did you clean and what did you use?
Thursday, May 30th, 2013 AT 6:57 AM
Recommended Guides
