Stalling out
JESSESGIRL
  • 1990 FORD F-150
  • 4,000,000 MILES
Check engine light came on truck started shifting hard and then we went to crank it the next morning and it would idle low when put in reverse or drive it shuts off. What could my problem be?
Do you
have the same problem?
Monday, May 1st, 2017 AT 9:34 AM
CARADIODOC
  • EXPERT
The Check Engine light means the Engine Computer detected a problem, and set a diagnostic fault code. The place to start is by having those codes read and recorded. They will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. The people at many auto parts stores will read those codes for you for free.
Monday, May 1st, 2017 AT 2:35 PM
Recommended Guides
