Speedometer not working
JZ8WZD1
  • 1994 FORD F-150
  • 5.0L
  • V8
  • MANUAL
  • 170,000 MILES
The speedomter quit working and the ABS warning lite came on at the same time. Is there a fuse or breaker that needs to be replaced or do I need the pcm reset or replaced?
Monday, November 26th, 2018 AT 9:37 AM (Merged)
HMAC300
  • EXPERT
You need to scan for codes to see if the vss and or a sensor is bad for abs. A pro has to do that
JZ8WZD1
Thank ypu will have that done.
DOUGAR48
  • 1990 FORD F-150
Transmission problem
1990 Ford F150 V8 Four Wheel Drive Manual 200+ miles
This truck has over 200,000 miles on it but in good shape. I had it painted last week and when I got it back I noticed that the speedometer was not working.I pulled the cable end out of the transmission, took the cable out, hooked up a drill to it and it operated the guage needle. I did the same with the gear back on the end of the cable. I replaced the speed sensor and reinstalled with the old driven gear. It worked sporadically for a few days but now does not work at all. What do you think the problem is?
BMRFIXIT
  • EXPERT
Check the sensor gear if slipping also check the driver gear in the tranny
check the cable ends
WONDO82
  • 1994 FORD F-150
1994 Ford F150 6 cyl Two Wheel Drive
my speedometer started acting wacky and then just stopped working how do I fix this problem I checked my fuses and my other gauges work fine is it some kind of sensor
BLUELIGHTNIN6
  • EXPERT
Suspect faulty speed sensor or faulty wiring to speed sensor. You should follow test steps below to pinpoint the exact problem though.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1787.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_565.jpg
EWALLYN
  • 1991 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 150,000 MILES
Just bought a truck and the speedometer doesn't work. How is the cable routed? Does it go to the transmission, transfer case or rear end? Also does it run in the vicinity of the radio wiring inside the cab?
Thank you
Monday, November 26th, 2018 AT 9:38 AM (Merged)
BLUELIGHTNIN6
  • EXPERT
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2731.jpg
CHIFLADO
  • 1998 FORD F-150
  • 6 CYL
  • 156,000 MILES
I have a 98' ford f-150 I replaced the speed sensor for a new one, even tried out another speedometer cluster and still the speedometer does not work, all the other needles work fine. And once in a blue the speedo jumps for a few seconds then it goes back down. What could be the prolem? Please help.
ERNEST CLARK
  • EXPERT
The wire/connector from the speedo at the tranny to the dash may be bad.
ORDIE1969
  • 1994 FORD F-150
  • V8
  • 96,875 MILES
Speedo on my 1994 Ford F-150 is not working
DOCFIXIT
  • EXPERT
Maybe faulty Output speed sensor on left side trans tailshaft
ACCALIALEE@GMAIL.COM
  • 1997 FORD F-150
  • 4.6L
  • V8
  • 4WD
  • 260,000 MILES
The speedometer stopped working. The odometer is still working along with all the gages. What could it be?
HMAC300
  • EXPERT
If the odometer works but speedo doesn't then it's more than likely the speedo head and will need repair.
WALTER WOOD
The transmission still has a over firm shift and occasional shutter going in and out of overdrive. I am going to try fluid filter first. Anyone having the same issues run down the solid green and solid red wires for speed sensor in rear differential. I bypassed the yellow with green stripe wire from just below the tank to the cab for the gas gauge, could not find the short, took me two weeks and $30.00 and Mr Ken to find these three wires.
Monday, November 26th, 2018 AT 9:42 AM
KEN
  • ADMIN
Hi Walter, lets start a new thread, I thought this one was done so I merged it.
Please post your new question here, you must be logged in.
Cheers, Ken
Monday, November 26th, 2018 AT 10:16 AM
