Will not start after changing the head gasket
ULRICH VALIES
  • 2001 NISSAN
  • 2.0L
  • 4 CYL
  • 4WD
  • 5,000 MILES
I have an X-Trail and it gets no spark on ignition coils still, change camshaft and crankshaft sensor, still no spark. These all came after I change the head gasket.
Do you
have the same problem?
Tuesday, October 4th, 2016 AT 12:34 PM
KEN
  • ADMIN
It sounds like you may have left off a system ground this will disable the ignition and fuel system from the engine. Did you scan for codes? Also check all fuses it might have popped something.
Here is the wiring diagram for that.
Also check the ignition module and the power transistor.
Please let us know what you find so it will help others.
Best, Ken
Tuesday, October 4th, 2016 AT 1:34 PM
Recommended Guides
