Smoking from exhaust
DEVHANNAH
  • 2006 MERCEDES BENZ E230
  • 3.4L
  • TURBO
  • 4WD
  • 12,355 MILES
I normally spray perfume when it is not starting so now it is smoking badly from the exhaust.
Do you
have the same problem?
Sunday, February 12th, 2017 AT 1:32 PM
CARADIODOC
  • EXPERT
You are obviously using the wrong brand of perfume!
You are going to have to add a real lot of detail, clues, or observations. Where are you spraying whatever it is you are spraying? What problem is that supposed to solve? When does the smoking occur? Is the smoke blue, black, or white? Does it occur all the time the engine is running? Is the level dropping in the coolant reservoir?
Monday, February 13th, 2017 AT 9:26 AM
Recommended Guides
