Smoke after starting and siting after running for awhile.
DEUCE04
  • 1991 FORD MUSTANG
  • 5.0L
  • V8
  • RWD
  • MANUAL
  • 500 MILES
Have a new short block installed cobra heads, cobra intake, shorty headers, b cam, all new parts. When I start the car after seeing for a few days it puts out a smoke screen. After I run it for 60 miles or so and cut it off then restart it again it puts out a puff of smoke. I ck the oil and it uses about a half quart or so. I drive it several times a month when it is pretty outside. All new engine in this car. Had it dyno and it has 325 to motor and 277 to the rear wheels. Excellent car, but worried about the oil uses. Thanks
Do you
have the same problem?
Sunday, March 9th, 2014 AT 12:58 PM
HMAC300
  • EXPERT
Check for bad valve seals or a head gasket problem.
Tuesday, March 11th, 2014 AT 8:35 AM
Recommended Guides
