Smart junction box
HAHNY1
  • 2006 FORD FUSION
  • 3.0L
  • V6
  • 78,000 MILES
Can I replace the smart junction box using a used one or does it have to be programmed to the car? The right front blinker quit working and all others still work. Can the smart junction box be fixed?
I switched the bulb and socket from the other side, checked all the fuses, and when I ran out of ideas took it to a mechanic and confirmed it
Do you
have the same problem?
Tuesday, August 16th, 2016 AT 5:30 PM
2CARPROS KEN
  • ADMIN
  • 9,409 POSTS
Here is a location and the diagram on how to change it. (Below)
Cheers, Ken
Wednesday, July 26th, 2017 AT 7:42 PM
LEGITIMATE007
  • EXPERT
  • 5,215 POSTS
You must replace the flasher fuse relay
Wednesday, July 26th, 2017 AT 7:48 PM (Merged)
HMAC300
  • EXPERT
  • 49,839 POSTS
Check fuses in car and underhood first
Recommended Guides
