Jerking on low RPM
NEILL23
  • 2002 NISSAN ALMERA
  • 245,000 MILES
The car jerks on low rpm nissan told me that it is the cam and crank sensors I replaced it and the problem is still the same if not worst then before I also changed the spark plugs and the air flow meter what els can be the problem please assist me
Wednesday, July 31st, 2013 AT 3:28 AM
HMAC300
  • 48,601 POSTS
This sounds like the engine is misfiring here is a guide to help you fix it.
Wednesday, July 31st, 2013 AT 7:16 AM
BOOPERIII
Thanks for this guide I installed a new set of spark plugs fixed it! I love this site
Saturday, June 1st, 2019 AT 3:48 PM
STE HUGHES
  • 2003 NISSAN ALMERA
  • 1.5L
  • 4 CYL
  • FWD
  • MANUAL
  • 10,000 MILES
When I start off in first gear there is very little acceleration and then the power kicks in as normal. Then I change to second and its the same. There is just high revs with no power (acceleration) and then the acceleration kicks in a short while after changing into second gear. It is the same in third gear but fine in fourth and fifth. What could the problem be?
Saturday, June 1st, 2019 AT 3:49 PM (Merged)
HMAC300
  • 48,601 POSTS
Sounds like your clutch is slipping. Check fluid level if hydraulic and see if there is an adjustment to it. It can also be something bent or clutch is bad, so have a local mechanic check it.
ORLAAINEBILLY
  • 2001 NISSAN ALMERA
  • 119,000 MILES
I have changed the trottle body, the air flow sensor and the idle air flow meter. This has not fixed the problem. Any idea what else could it be. Only changed the idle air flow meter today. Drove it for a while and it seemed fine but when I went to drive it again it revved up again.
CJ MEDEVAC
  • 11,004 POSTS
LOOK REALLY GOOD FOR A VACUUM LEAK
THE MEDIC
ORLAAINEBILLY
Done that. Stil no joy. No vacuum leak
CJ MEDEVAC
  • 11,004 POSTS
Just for giggles, how did you search for a vac leak?
I sorta keep forgetting about all of the new stuff they have added
I usually just jump on and start answering---hopin' to find a cj in need!
I sorta did a little 2carpro site surfing there's lots of stuff i ain't seen yet, got more surfin' to do to see what's on here now....see if this helps
Http://www.2carpros.com/articles/engine-idles-too-high
The medic
JOHNNY5
  • 2000 NISSAN ALMERA
  • 95,000 MILES
Hi my Nissan Almera model is stuttering as I drive also the rev meter is shaking up and down but I just recently got the spark plugs changed I am just wondering what could be the problem.
When I am driving it is like it is pulling back. It is common occurrence as I drive
  • 108,170 POSTS
If it started since you got the plugs, check to make sure the plug wires are on the correct plugs and the coil wire is in good condition. If they are, you need to check the plugs to make sure they are gaped properly and all working.
JANCOL10
  • 92,000 MILES
I changed the Trottle body in my 01almera 1.5 as the revs are going from 1500 to 2000 on idleing speed I also put it on 2 cumputers and their are no problems showing up there are no air pips bursted
RIVERMIKERAT
  • 6,110 POSTS
So after the new throttle body you're still having idle fluctuations? Have you scanned it for codes? Checked and cleaned the idle control valve? Checked for vacuum leaks?
JANCOL10
Yes to all no codes no leaks and cleaned everything so lost for reasons
Is it possible it could be a sencor without a code shown for it?
RIVERMIKERAT
  • 6,110 POSTS
Check compression. Check timing. There could be soft codes that don't cause a CEL to be set.
JANCOL10
Still no different tryed all these things just looked at the ECU and its not the one that came with the car what could be wrong with this as the car drives great if I keep it over 2000revs so it must have been put in right or was it?
RIVERMIKERAT
  • 6,110 POSTS
It could be the wrong computer. It could be bad connections.
FARRISCADO
  • 1997 NISSAN ALMERA
In continuation of my previous question. I had to replace the "sensor camshaft position" because it brake and since then I started noticing the priorly reffered problem of RPM break. I also replaced the ignition coil, the distributor cap andthe rotor.
KHLOW2008
  • 41,815 POSTS
You should be replying to your previous post instead of posting a new question as we need to have the history of what had transpired to understand the situation.
FARRISCADO
Since I have already tryed the solution which was suggested in the first answer. I thought I could give more pointers than I had already given.
KHLOW2008
  • 41,815 POSTS
