Signal light/brake light problem
MERCURMAN
  • 1987 TOYOTA PICKUP
  • 2.2L
  • 4 CYL
  • MANUAL
  • 150,000 MILES
My pick up right turn signal lights blink fast, but do not work. Also, the right rear brake light does not work. All of the other lights work both of these problems started at the same time.
Do you
have the same problem?
Monday, May 15th, 2017 AT 7:36 AM
HMAC300
  • EXPERT
I am assuming the right side is the one blinking fast. Have you checked the bulb yet? Also the ground to the rear taillight will cause this. Check the green/yellow wire coming from turn signal switch for power then check at rear if coming from switch and not to light then wire is broken between the black/white wire is ground so follow that back probably on frame someplace. If power comes to light socket it may be bad.
Monday, May 15th, 2017 AT 8:33 AM
Recommended Guides
