Shutdown at stop signs and red lights
KAPITON121
  • 1995 FORD F-150
  • 4.9L
  • 6 CYL
  • MANUAL
  • 15,000 MILES
While replacing a bad freeze plug behind the flywheel I found a broken wire, I repaired the wire and now it will not stay running. I have been trying to find a way to check for fuel pressure but can’t find a way.
Do you
have the same problem?
Wednesday, July 21st, 2021 AT 12:16 PM
BMDOUBLE
  • EXPERT
The fuel schrader valve location is at the rear of the right side of the engine (picture attached). I have also attached the pressure specifications. This is a great place to start, just to get an idea of the health of the fuel system. Also verify that the EGR valve is not stuck open (common issue). Here are also some repair guides that should help:
https://www.2carpros.com/articles/stall-at-idle
Wednesday, July 21st, 2021 AT 12:53 PM
