Shift solenoid I think 2000 Ford Focus 3rd gear
CFOCUS
  • 2000 FORD FOCUS
  • 80,000 MILES
While driving goes into 3rd gear but then when my to.S go up or I go over idk 30mph it disengaged then when let off gas or let rev down it engages again. Sounds like a solenoid but no codes? I need help nobody knows what it is here sounds like solenoid to me but why no codes any help would be very helpful.
Thursday, August 8th, 2013 AT 12:02 AM
KHLOW2008
  • 41,815 POSTS
Sometimes codes do not show because the solenoids are working correctly electrically but the mechnical side is leaking causing pressure drop. I would suggest checking the fluid condition and filter. If filter is partially clogged or level is low, insufficient fluid movement would cause symptoms as well.
Thursday, August 8th, 2013 AT 4:30 AM
CFOCUS
  • 6 POSTS
Ok fluid level is ok idk about filter yet don't want to drain fluid an take pan off to switch filter out then just to have to replace solenoid after an waste fluid when drain again an waste it. Isn't it a special type of fluid also. So other then fluid low or filter being clogge is there anyway way a solenoid could be malfunctioning without a code. Fluid looks clean so guessing filter is good also
Thursday, August 8th, 2013 AT 5:00 AM
KHLOW2008
  • 41,815 POSTS
Chart shows the solenoid operations in the various modes. Did you test if there is any difference when OD button is turned on or off?
For testings of solenoid operations, a scan tool would be the easiest way to go about. It can read the various circuits and allows you to test the solenoids.
Thursday, August 8th, 2013 AT 10:03 PM
CFOCUS
  • 6 POSTS
Ok well like said don't have codes coming up but same symptom as soliniod how can I test them to seeif working properly
Friday, August 9th, 2013 AT 4:38 PM
KHLOW2008
  • 41,815 POSTS
You need a scan tool to test the solenoids.
Friday, August 9th, 2013 AT 6:03 PM
CFOCUS
  • 6 POSTS
Ya I know I already said that no codes are coming up with code scanner I have one. Like said no codes coming up on scanner.
Friday, August 9th, 2013 AT 6:21 PM
CFOCUS
  • 6 POSTS
I think it's a mechical issue with one of them sticking or something are u talking about a OBD2 scanner
Friday, August 9th, 2013 AT 6:22 PM
KHLOW2008
  • 41,815 POSTS
A scan tool can be used to activate the solenoids to see if they are working correctly. You don't need any codes to do that. How much do you know about cars anc scan tools?
If you want to do it old school, remove the solenoids and test them individually.
Friday, August 9th, 2013 AT 6:48 PM
KHLOW2008
  • 41,815 POSTS
By the way when I say scan tool, I mean the real thing, not a code reader.
Friday, August 9th, 2013 AT 6:57 PM
CFOCUS
  • 6 POSTS
Oh ok well I live on st thoms in the virigin islands I don't think they have the scan tool anywhere here. How do I test the solenoids manually to make sure they are moving an working
Friday, August 9th, 2013 AT 7:09 PM
KHLOW2008
  • 41,815 POSTS
VALVE BODY SOLENOIDS
Raise and support vehicle. Remove transaxle oil pan to access valve body solenoid assembly. Disconnect solenoid wire connector(s). See Fig. 3. Using an ohmmeter, measure resistance between specified terminal(s) and solenoid body. See VALVE BODY SOLENOID RESISTANCE table. See Fig. 7. If resistance(s) is within specification, solenoid is okay at this time. If resistance(s) is not within specification, replace faulty solenoid(s) and retest system operation.
Saturday, August 10th, 2013 AT 4:56 AM
