Shaking
ERIK1199
  • 2000 DODGE STRATUS
  • 160,000 MILES
Hi I started my car this morning and the whole car began to shake, I also looked at the engine and it too was shaking violently. I could be wrong but it also sounded like it turn over all the way. This has never happened before. Recently I had two of the engine mounts replaced.
Do you
have the same problem?
Monday, April 29th, 2013 AT 12:35 PM
JDL
  • EXPERT
How long since a tune-up? Can you check for applicable trouble codes?
Monday, April 29th, 2013 AT 12:56 PM
CARADIODOC
  • EXPERT
Not sure what you mean by "turn over all the way", but shaking is due to a misfire. That could be as simple as bad spark plugs and wires, or a bad ignition coil, depending on which engine you have.
Monday, April 29th, 2013 AT 12:57 PM
JDL
  • EXPERT
To check for codes, at the least, you need an obd2 code reader. Your local autostore should have them.
Monday, April 29th, 2013 AT 1:00 PM
Recommended Guides
