Serpentine belt replacement
JACK FRY
  • 1996 FORD F-250
  • 7.3L
  • 4WD
  • 111,000 MILES
What size socket goes on the tensioner pulley to use the belt removal tool?
Do you
have the same problem?
Thursday, February 9th, 2017 AT 9:30 AM
CARADIODOC
  • EXPERT
It should be a 15mm. But we just look at what type of tool is needed, and if it's an open-end wrench or socket, we try a few to find the right one. Some replacements use a square drive, usually 1/2", as found on the end of a ratchet or breaker bar.
Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/replace-serpentine-belt
and
https://www.2carpros.com/diagrams/ford/pickup/1996
Cheers
Thursday, February 9th, 2017 AT 3:32 PM
JACK FRY
Thank you I got the job done the links really helped!
Thursday, February 9th, 2017 AT 3:59 PM
CARADIODOC
  • EXPERT
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Thursday, February 9th, 2017 AT 6:09 PM
Recommended Guides
