1998 Saturn SL1 sometimes won't start
HELP13612
  • 1998 SATURN SL1
Electrical problem
1998 Saturn SL1 4 cyl Front Wheel Drive Automatic
sometimes the car won't start, will crank not fire
could it be a relay in the iignition or that key is worn?
Do you
have the same problem?
Wednesday, January 6th, 2010 AT 8:33 AM
SATURNTECH9
  • EXPERT
First of all we need to see if were loosing spark or fuel when it doesn't start. The easiest thing to check for is spark when it doesn't start take off two sparkplug wires next to each other on the coil have someone crank it over see if u get spark. If u do then we will have to get a fuel pressure gauge and see if we have fuel pressure. Also do u have any codes?U can get ur codes rea at the auto parts store.
Wednesday, January 6th, 2010 AT 1:38 PM
Recommended Guides
