1997 Saturn SL1 excessive pedal travel
JBANG5
  • 1997 SATURN SL1
  • 4 CYL
  • FWD
  • 115,000 MILES
I just replaced the front brake pads, rotors, and calipers, bled all 4 brakes and still the pedal travel to the max extent even after pumping the pedal. I hyave checked for leaks and find none and the fluid level is constant. I'm stumped unless I have a bad master cylendar I can't figure out what my problem is. ANy help?
Do you
have the same problem?
Sunday, May 31st, 2009 AT 4:35 PM
Replace the master cylinder
Sunday, May 31st, 2009 AT 5:54 PM
Recommended Guides
