1998 Saturn Sedan Stalling upon take-off
PAIKMAN2000
  • 1998 SATURN SEDAN
Engine Mechanical problem
1998 Saturn Sedan 4 cyl Two Wheel Drive Automatic
My friend's '98 Saturn Sedan stalls out intermittenly upon take-off. She says it usually does it after a long traffic light and the car cuts out when she hits the gas. The Crank Position Sensor was replaced a few days ago.
Do you
have the same problem?
Friday, November 14th, 2008 AT 5:02 PM
JNOVACK
  • EXPERT
Check the fuel pressure it should be 40-55 PSI(Pounds per Square Inch)
Note: Position the ignition switch and the A/C system in the
off position. Install a fuel pressure gauge to the
vehicles fuel pressure test port. Confirm that
no leaks are present, and energize the fuel pump by
utilizing the scan tool instrument.
Visually verify the PSI reading on the gauge
also check the fuel filter
Friday, November 14th, 2008 AT 5:13 PM
Recommended Guides
