2001 Saturn manual transmission
CROCK5677
  • 2001 SATURN
Hi, have a 2001 manual transmission saturn 169000 miles that I just put a new to the car transmission in along with new clutch plate, forks, master and slave clinder in. Worked fine for about 500 miles now it has trouble going into gears. Parked it on a slight hill facing down and had no problem going into gear. What else do I need to look at as this is the 2nd tranny in 3 months?Thanks for any advice you can give.
Do you
have the same problem?
Wednesday, April 11th, 2007 AT 4:48 PM
JACK42
Adjust the rod that goes into the master
Monday, April 16th, 2007 AT 8:07 AM
Recommended Guides
