2000 Saturn L200 Transmission suddenly quit working
SGREENE21
  • 2000 SATURN L200
  • 6 CYL
  • 160,000 MILES
All of a sudden, the trasmission quit working. Won't move in any gear. The flui smells fine, so I believe it must be electrical. Can you point me in a directtion. Then also tell me why they don't have trans dip stick.
Thanks,
Steve
Do you
have the same problem?
Sunday, May 30th, 2010 AT 2:53 PM
SATURNTECH9
  • EXPERT
All the L model saturns I have seen that suddenly quit moving had bad transmissions not a electricial problem. They don't have a dipstick they have a sight level hole that tells you it's full when fluid comes out of the hole it's a more precise way of setting the fluid level. You haven't changed the fluid yet right?I need you to rent a code reader and tell me what codes you have let start there.
Monday, May 31st, 2010 AT 1:21 PM
Recommended Guides
