2000 Saturn L200
STLEEGL2
  • 2000 SATURN L200
2000 Saturn L200
This car is surging up to about 50mph or at part open throttle and also stubbles from a idle as you accelerate. Can you shed some possible causes as I am thinking it may be the tps. Any help would be appreciated thanks.
Do you
have the same problem?
Sunday, January 10th, 2010 AT 7:25 PM
BASSTECH
A bad TPS could do it, but that should set the check engine light on, and you will need a diagnostic tool to see if it's working correctly. Some other thoughts. Bad gas, run the tank down to empty and refill, see if that helps.
Also it could be a bad ignition module that fires the spark plugs, does it feel like it has a miss at idle or when it's under a load, as in drive?
Friday, February 12th, 2010 AT 6:36 PM
Recommended Guides
