Removal Radiator
FBILDER
  • 1999 SAAB 9-3
  • 4 CYL
  • FWD
  • MANUAL
  • 88,000 MILES
I can not figure out how to get Radiator out of the car?
Wednesday, November 3rd, 2010 AT 2:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to show you step by step how to replace the radiator and the diagrams below to help you see what it will be like on your car.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
Cheers
Wednesday, November 3rd, 2010 AT 6:57 PM
FBILDER
That you so much I did it but it took all day ;) cost me $147.00 for the radiator.
Thursday, November 4th, 2010 AT 10:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Thursday, November 4th, 2010 AT 8:49 PM
SAABENTHUSIASTS2010
  • 1999 SAAB 9-3
  • 150,000 MILES
I have a the car listed above it is a turbo, automatic. I read the solution here and well here is how it went. I took off the air filter hose, the radiator fan and shroud (did it in one try they are both connected) unbolted the two bolts for the oil and the radiator hoses, took off the two clips, and when I tried to take the radiator off it just will not do it. Moves but cannot take it off where the rubber mounts are secured by the two clips.
If there are any pictures of a step by step that would be great.
Saturday, August 25th, 2018 AT 6:46 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
You should drain the radiator before you begin. Here is a guide that will help you get started and see what you are in for when doing the job:
Here are some diagrams of your car (below).
Cheers!
FROGGYDAVEY
  • 2001 SAAB 9-3
  • 4 CYL
  • FWD
  • 10,056 MILES
The temperature in car goes hot then stays cold most of the time. I have also changed temperature sensor and thermo and one of the pipes get really hot. Is the one that goes to the thermo to radiator? All pipes are hot, so I cannot understand why I got problem. Please help, thanks
TRON2007
  • 15 POSTS
When the cooling temperature goes above very hot.
You check the Cooling is bellow, check if the radiator is liking, check maybe the water pump or thermostat dosen't not work.
