Rocker panel filled with water and passenger carpet wet
HULLINGER64
  • 1991 MAZDA MIATA
  • 148,500 MILES
Rocker panels, at least, were filled with water and made sloshing sound.
Weep holes are clogged and now cleared by sticking paper clip up into hole to clear it. Water poured out of passenger side only. Carpet on passenger side of interior was soaked also which means back up and overflow not car occured.
Are there any other area filled with water and what do I check and how do I prevent rust?
Do you
have the same problem?
Thursday, July 4th, 2013 AT 6:19 AM
HMAC300
  • EXPERT
Not much you can do about rust other than to let it completely dry out then maybe drill holes where they can't be seen and spray in undercoating.
Thursday, July 4th, 2013 AT 8:39 AM
Recommended Guides
