Replacing transmission shifting cable
PATRICIA VELA
  • 2008 CHEVROLET MALIBU
  • 3.5L
  • 6 CYL
  • FWD
  • 84,000 MILES
Cable tip came off the transmission shifter.
Do you
have the same problem?
Monday, March 6th, 2017 AT 3:49 PM
STEVE W.
  • EXPERT
Not a bad job, except for all the trim tabs you need to pop free on the console trim.
However, you might want to call a dealer and have them run the VIN. There was a recall on the shift cables on those cars.
Also, which part actually failed, the black molded section or the internal plastic bushing? If it is the bushing there are kits available to replace them without removing the cable. Bushingfix. Com
Monday, March 6th, 2017 AT 5:08 PM
Recommended Guides
