Remove high pressure power steering line from steering box
CODYJONES08
  • 1997 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
I can not figure out how to remove the high pressure power steering line from the steering box. Ive tried a crows foot, open end wrench, but nothing seems to work. Please help me remove the high pressure power steering line from the steering box.
Do you
have the same problem?
Sunday, May 31st, 2015 AT 6:59 AM
HMAC300
  • EXPERT
It's pretty much cut and dried, especially with a line wrench are you turning it counter clockwise? That is the way it should go. Don' tknow what else to tell you
Sunday, May 31st, 2015 AT 8:16 AM
CODYJONES08
Yes I turned the wing nut counter clock wise, I figured out how to remove the line thanks guys. I had to remove the fuel sensor located near the air intake and then I was able to slide a crows foot with a long extension onto the wing nut and remove it that way.
Tuesday, June 2nd, 2015 AT 2:35 PM
Recommended Guides
