After replacing the cylinder head I do not have power going to the coil or crank sensor
DANIEL SIEGERS
  • 1999 DODGE STRATUS
  • 2.0L
  • 4 CYL
  • FWD
  • MANUAL
  • 226,000 MILES
I just recently replaced my cylinder head on my car. Car ran before I replaced the cylinder head. I have no power going to my coil and crank sensor. Can someone please help me?
Do you
have the same problem?
Sunday, January 8th, 2017 AT 6:36 PM
CARADIODOC
  • EXPERT
When or what are you doing when you are expecting to have voltage to the ignition coil? What are the exact symptoms you are trying to solve? I am guessing the starter is cranking the engine. Have you checked for spark and injector pulses? Does the fuel pump hum for one second when you turn on the ignition switch? What about diagnostic fault codes?
Monday, January 9th, 2017 AT 2:42 PM
Recommended Guides
