Radio lighter clock not working and wont dtart
KB989898
  • 2001 KIA SPORTAGE
  • 103,842 MILES
Radio ligjtet clock not working stuck in park and wont start check fuse and they are good changed the main relay and fuel pump relay still no start help I check for voltage at the fuse there is no voltage present not sure what else I can try can you assist me with this issue
Do you
have the same problem?
Tuesday, May 7th, 2013 AT 2:09 PM
  • EXPERT
Start with battery test. Re test all fuses with a test light to verify power. You may have a harness issue
roy
Tuesday, May 7th, 2013 AT 4:39 PM
