Puting 1987 B2200 engine with standard transmission into a 1990 B2200 witch is an automatic.
JASON77777
  • 1991 MAZDA B2200
  • 175,000 MILES
I'm thinking of putting an engine and standard transmission from a 1987 b2200 into my 1990 b2200 witch previously had an automatic transmission. Will the engine and trany fit ok? What kind of adjustments would I have to make? Will the drive shaft from the 91 connect to the 87 transmission. I'm guessing I would need a wire harness and computer for an 87 standard transmission and or what else would I need to do. Does a computer from a 88 b2600 work with an 87 engine and transmission.
Do you
have the same problem?
Tuesday, October 15th, 2013 AT 1:12 PM
  • EXPERT
We only recommend direct fit parts.
Tuesday, October 15th, 2013 AT 4:26 PM
Recommended Guides
