Fuel pump relay
NANMART79
  • 2001 MITSUBISHI ECLIPSE
Four cylinder two wheel drive automatic 16,000 miles.
Where is the fuel pump relay located on this vehicle?
Sunday, May 31st, 2009 AT 2:43 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
The fuel pump relay is located under the hood in the relay center. Here is a guide that will help you do some testing.
https://www.2carpros.com/forum/automotive_pictures/188069_01eclipserelaybox_1.jpg
Here is the location BELOW
Cheers, Ken
Friday, November 17th, 2017 AT 6:12 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2002 MITSUBISHI ECLIPSE
  • 78,000 MILES
Where is the fuel pump relay located on vehicle.
Friday, November 17th, 2017 AT 6:13 PM (Merged)
  • 52,797 POSTS
EMORENOENRIQUE
  • 2000 MITSUBISHI ECLIPSE
  • 308,000 MILES
My car's engine shut off while I was driving and I tried to turn it on but will not start. It sounds as if the gas is not passing through. I don't know if it's the fuel pump, the relay, please help me find the problem.
Thanks,
Enrique
SATURNTECH9
  • 30,870 POSTS
Do you have a multimeter to do some testing?If so we can see if there is power and ground going to the fuel pump.
RONNY MARSDEN
  • 1996 MITSUBISHI ECLIPSE
  • 20,000 MILES
I looking for a diagram for where to remove and install fuel pump relay (none turbo).
HARRY P
  • 2,293 POSTS
This is under the hood, drivers side if I am not mistaken.
RONNY MARSDEN
Mine only had two in that same area it sure help after seeing three other diagrams. So I picked the left one our if the two and it works now. Thank you
HARRY P
  • 2,293 POSTS
Glad we could help.
