Proton - brake lights on after engine switched off
IANHHH
  • 2000 PROTON
  • 55,000 MILES
Hi. I have a proton wira and recently noticed that sometimes the brake lights are still on after I have parked and locked the car. It is very strange, didn't think this should be possible when the engine is off! When I press the peddle the lights go off but obviously I am now having to check everytime I park and paranoid about returning to my car with the battery flat.
what do you think. Do I need to change or adjust the brake light switch or is it more likely an electrical short circuit?
thanks.
Do you
have the same problem?
Monday, July 22nd, 2013 AT 12:10 AM
KHLOW2008
  • EXPERT
Check the brake pedal switch adjustment.
Wednesday, July 24th, 2013 AT 7:49 AM
Recommended Guides
