Proportioning valve break warning light is leaking out the top (brand new warning light valve)
1974 F350
  • 1974 FORD F-350
  • 171,000 MILES
Proportioning valve (old) break warning light valve is leaking from the top(new) old one was leaking out the top also(where the wires are plugged into)THE NEW BREAK WARNING LIGHT VALVE IS STILL LEAKING BREAK FLUID OUT OF THE TOP WHERE THE ELECTRICAL WIRES ARE PLUGGED INTO
Do you
have the same problem?
Monday, August 12th, 2013 AT 12:27 PM
HMAC300
  • EXPERT
Replace the switch that he wires connect to
Monday, August 12th, 2013 AT 12:38 PM
Recommended Guides
