1995 Pontiac Trans Am car cutting out, wont restart for a f
NICK328NW
  • 1995 PONTIAC TRANS AM
Electrical problem
1995 Pontiac Trans Am Two Wheel Drive Manual
when driving the car will just cut out the lights and radio all still work and the car will try and fire up but it just will just keep cracking. Then when I let it set for a few min it will restart and drive fine till it dies again.
Do you
have the same problem?
Saturday, March 6th, 2010 AT 11:09 AM
JDL
  • EXPERT
Hi, If it cranks good but won't start, when the problem occurs, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. How long since a tun-up? You need to test when the problem occurs.
Saturday, March 6th, 2010 AT 11:16 AM
CHRISJJ3
My car does the same thing. Maybe look into the Egr Valve.
Tuesday, January 11th, 2011 AT 10:44 PM
JDL
  • EXPERT
Did you ever get a chance to do any testing?
Tuesday, March 1st, 2011 AT 10:24 PM
Recommended Guides
