1997 Pontiac Sunfire timing chain tensioner
RUFUS97
  • 1997 PONTIAC SUNFIRE
  • 4 CYL
  • 188,000 MILES
How do I reset the timing chain tensioner?
Do you
have the same problem?
Saturday, December 29th, 2007 AT 6:20 PM
PJ(GTO)
Is this motor the quad four model? Also are you currently replacing the timing chain? If the answers are both yes. The tensioner is reset by pushing down on the tensioner cam/spring assembly, it will click and pop outward and then it will automaticlly set to the right tension, when you get the tensioner assembly from the parts store, there is a plasic spacer that prevents it from being engaged accidentlly that you need to remove after the chain is installed correctlly. Then just push down. Thanks I hope that helps, but if it is a different engine model, i'm sorry I can't help you there.
Sunday, December 30th, 2007 AT 3:29 AM
