1997 Pontiac Sunfire runs ruff at idle
CSSPY009
  • 1997 PONTIAC SUNFIRE
Engine Mechanical problem
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
engine sputters as if the mass air flow sensor was going bad. Car doesn't have one. On the trottle body next to the butterfly is a round hole about the size of a nickle, when I spray mass air flow sensor cleaner in the hole and wait for it to evaporate the car runs fine for about 30 minutes. Afterwards it starts to sputter again.
Do you
have the same problem?
Tuesday, May 6th, 2008 AT 11:03 AM
Try cleaning out the idle air control valve
Tuesday, May 6th, 2008 AT 12:13 PM
Recommended Guides
