1996 Pontia Sunfire GT
DJONES
  • 1996 PONTIAC SUNFIRE
I am having a problem figuring out what else to do. My Sunfire is not firing on the #4 cylinder. We have checked the Ignition control module and tested the Ignition coil and the car shakes when it runs. The car runs like a tractor. We have also replace the crank shaft sensor and we replaced the fuel injector for the #4 cylinder and also did a tune up of new spark plugs and wires or the boots.
The car has 140,000 miles on it.
Can anyone tell what I can do to make this car run normal?
Thank you
DJones
Do you
have the same problem?
Sunday, September 16th, 2007 AT 11:59 AM
SERVICE WRITER
  • EXPERT
Check the compression on that cylinder.
Sunday, September 16th, 2007 AT 8:26 PM
Recommended Guides
