2002 Pontiac Montana Sliding doors and rear backup alert -
VSOWDER
  • 2002 PONTIAC MONTANA
  • 6 CYL
  • FWD
  • 126,000 MILES
The sliding doors stopped working along with the backup alerts not working - Could this be a fuse problem?
Also the driver's side power window will not operate
Do you
have the same problem?
Saturday, April 10th, 2010 AT 10:29 AM
FACTORYJACK
  • EXPERT
Do the stoplamps work? The IGN 1 fuse in the i/p fuse block controls power to the rear object sensors, and both rear side doors. If the fuse is good, you could have a circuit fault, I would check the pink wire for power at pin G3(I/P side,Key on), of connector C203. I don't show a picture of this connector location, just a description, and the connector end view, here it is;
C203 (56 cavities)
IP wiring harness to the left side of the body wiring harness, left side of the steering column, below P101
http://www.2carpros.com/forum/automotive_pictures/309872_39794_1.jpg
Connector Part Information
" 12034257
" 56-Way F Metri-Pack Mixed Series (BLK)
" 12186339
" 56-Way M Metri-Pack Mixed Series (BLK)
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A1
ORN
1052
Auxiliary Blower Motor Supply Voltage
A1
ORN
1052
A2
YEL
18
Left Rear Stop/Turn Lamp Supply Voltage
A2
YEL
18
A3
DK GRN
19
Right Rear Stop/Turn Lamp Supply Voltage
A3
DK GRN
19
A4
LT BLU
1134
Park Brake Switch Signal
A4
LT BLU
1134
LT BLU
1134
A6
Not Used
A6
Not Used
A7
GRY
778
Auxiliary Blower Motor Speed Control
A7
GRY
778
A8
WHT
17
Stop Lamp Switch Signal
A8
WHT
17
A9
BRN
241
Ignition 3 Voltage
A9
BRN
241
Ignition 3 Voltage
B1
WHT
615
Memory 1 Switch Signal
B1
WHT
615
B2
GRY
391
Rear Window Wiper Switch Signal
B2
GRY
391
B3
BRN
882
Right Rear Wheel Speed Sensor Signal
B3
BRN
882
B4
WHT
883
Right Rear Wheel Speed Sensor Low Reference
B4
WHT
883
B6
BRN
9
Park Lamp Supply Voltage
B6
BRN
9
B7
WHT
393
Rear Window Wiper Motor Control
B7
WHT
393
B8
DK GRN
392
Rear Window Washer Pump Control
B8
DK GRN
392
B9
Not Used
B9
Not Used
C1
BLK
884
Left Rear Wheel Speed Sensor Signal
C1
BLK
884
C2
RED
885
Left Rear Wheel Speed Sensor Low Reference
C2
RED
885
C3
LT BLU
733
Air Temperature Door Position Signal
C3
LT BLU
733
C4
GRY
2700
5 Volt Reference
C4
GRY
2700
5 Volt Reference
C6
YEL
804
Door Ajar Indicator Control
C6
YEL
804
C7
DK BLU
1128
SDM Class 2 Serial Data
C7
DK BLU
1128
C8
PPL
1589
Fuel Level Sensor Signal
C8
PPL
1589
C9
YEL
1127
Class 2 Serial Data
C9
YEL
1127
Class 2 Serial Data
D1
LT BLU
1072
Auxiliary Blower Motor Medium Speed Control
D1
LT BLU
1072
D2
BLK/WHT
351
Ground
D2
BLK/WHT
351
Ground
D3
GRY
8
Instrument Panel Lamp Supply Voltage - 1
D3
GRY
8
D6
PPL
493
Rear Seat Audio Enable Signal
D6
PPL
493
D7
BLK
2759
Low Reference
D7
BLK
2759
Low Reference
D8
ORN
640
Battery Positive Voltage
D8
ORN
640
E1
DK BLU
46
Right Rear Speaker Output (+)
E1
DK BLU
46
E2
TAN
201
Left Front Speaker Output (+)
E2
TAN
201
E3
LT GRN
200
Right Front Speaker Output (+)
E3
LT GRN
200
E4
YEL
116
Left Rear Speaker Output (-)
E4
YEL
116
E6
LT BLU/
BLK
1505
Passenger Heated Seat Switch Signal
E6
LT BLU/
BLK
1505
E7
LT BLU
1462
E7
LT BLU
1462
E8
LT GRN
1011
Remote Radio Control Signal
E8
LT GRN
1011
E9
DK GRN
890
Fuel Tank Pressure Sensor Signal
E9
DK GRN
890
F1
GRY/BLK
308
Step Dim Signal
F1
GRY/BLK
308
Step Dim Signal
F2
PPL
616
Memory 2 Switch Signal
F2
PPL
616
F3
BRN/WHT
1048
Class 2 Serial Data
F3
BRN/WHT
1048
Class 2 Serial Data
F4
Not Used
F4
Not Used
F6
YEL
1176
Auxiliary Blower Motor Low Speed Control
F6
YEL
1176
F7
LT GRN/
BLK
24
Backup Lamp Supply Voltage
F7
LT GRN
24
F8
BLK
1550
Ground
F8
BLK
1550
Ground
F9
PNK
314
Radio On Signal
F9
PNK
314
Radio On Signal
G1
Not Used
G1
Not Used
G2
BRN
641
Ignition 3 Voltage
G2
BRN
641
Ignition 3 Voltage
G3
PNK
39
Ignition 1 Voltage
G3
PNK
39
Ignition 1 Voltage
G4
WHT
1310
EVAP Canister Vent Solenoid Control
G4
WHT
1310
G5
PNK/BLK
1303
Liftgate Ajar Switch Signal
G5
PNK/BLK
1303
G6
Not Used
G6
Not Used
G7
BRN
199
Left Rear Speaker Output (+)
G7
BRN
199
G8
LT BLU
115
Right Rear Speaker Output (-)
G8
LT BLU
115
G9
DK GRN
117
Right Front Speaker Output (-)
G9
DK GRN
117
G10
GRY
118
Left Front Speaker Output (-)
G10
GRY
118
Sunday, April 11th, 2010 AT 1:35 AM
Recommended Guides
