2005 Pontiac Grand Prix Overheats only while idling
BRANDONOHERN
  • 2005 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 134,000 MILES
My 2005 3.8 v6 Grand prix overheats while idle. No problem when the care is in motion. Even if temp gets to red, I can start driving and it cools down instantly. I have not noticed any coolant leaks yet. I watched the fans and they are pulling air through the radiator, when I turn the AC on it does not seem to increase any airflow.
Does anyone have any thoughts on what it could be? Or any other troubleshooting I should do?
Do you
have the same problem?
Wednesday, June 23rd, 2010 AT 10:15 PM
FACTORYJACK
  • EXPERT
What about not moving, and just increasing the engine speed? The only thing motion is doing is intruducing ram air through the radiator. I have not seen one, but it could be a logical symptom of a water pump that is not flowing adequately. Is this happening after something else had been done to the car, or just come on all of a sudden? Is this overheat occurring with only the A/C on, or does it overheat at idle with A/C off? You say you have not noticed any coolant leaks, but make no mention of coolant level, I would have to assume it has been checked and is full, with adequate coolant concentration.
Thursday, June 24th, 2010 AT 12:03 AM
BRANDONOHERN
Just idling is all I have tried. As soon as it started to heat up it, I took off down the road to cool it off. This came on all of a sudden no new work. It heats up even with AC off. The coolant level was a little low at my last oil change but nothing significant. That was before this occured.
Thursday, June 24th, 2010 AT 9:12 PM
FACTORYJACK
  • EXPERT
Try raising the speed stationary, if it cools it down, it may be a water flow problem. The cooling fans should have at least two speeds, and should speed up when it starts getting hot, I am not sure of the temp breakpoint. With a temp gun, you might be able to spot cool areas of the radiator, perhaps there is restricted flow. How quickly does it overheat at an idle?
Tuesday, June 29th, 2010 AT 10:16 PM
Recommended Guides
